You do not have a timing advance system in the distributor. It sounds like you are going lean when doing high accelerating.
Maybe a fuel pump or fuel pressure regulator. Put a fuel pressure gauge on the windshield and see if you are maintaining fuel pressure of 40-42 psi while accelerating.
This would also be a good time to see if you have any codes in CM of the computer. They may tell you what is wrong and we will not have to guess.
