So I'm looking to get a injector pump, cause the fuel shutoff soli. doesn't work. I can't find just the fss, so i guess i got to get the whole ip? So where's the cheapest one I can get? Thanks
If you go to change it, ask directions first.
Installed improperly, it can cause a run away engine with no way to turn it off other than cutting the fuel supply line if you can get it cut before the engine blows.
