Bolt circle info for 6-bolt pattern
Old Nov 25, 2009 | 05:20 AM
in-the-dena's Avatar
in-the-dena
Hello,
I am looking to upgrade my stock 255/70 tires rims with a set of Keystone black steel rims and 33" Nittos. I am adding a 3" Ready-Lift as well. I am having difficulty establishing what 6-Bolt circle information will fit my 2008 F-150 CC. There are numerous rim patterns that all end in the 16" diameter. A) Can I use a readily available 16 X 9 rim? Will they clear the calipers? B) What is the Bolt-circle info that I need to search for for my truck to keep the Ø17"?
Thanks.
DCN
Old Nov 25, 2009 | 01:10 PM
2004 xlt 5.4's Avatar
2004 xlt 5.4
There is only a very small gap between the rim and brake caliper putting a 16" on 17" may not work
Something to watch fore.
Old Nov 25, 2009 | 07:29 PM
JoSHN's Avatar
JoSHN
Your Bolt pattern is 6x135mm.
And unless I have been mistaken, a 16" rim will not fit around the caliper.
Old Nov 25, 2009 | 08:36 PM
jstnromero's Avatar
jstnromero
i second a 16" rim not fitting the f150's....even some of the 17's wont fit our trucks and yes the bolt pattern is 6X135
Old Nov 27, 2009 | 04:12 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
Blanket cover all statement = 16" rims will not fit at all
however, people have made them work...but they required alot of work, some grinding of the calipers and a specialized set of rims.
Old Nov 30, 2009 | 10:04 AM
in-the-dena
Huge help... Thanks to all for responding.
DCN
danlee
Mar 3, 2016 07:08 PM
jaskoskip
Jan 1, 2016 11:08 AM
Redneck1465
WTB - Parts & other
17
Mar 1, 2013 05:14 AM
originalzman
Feb 2, 2012 05:33 PM
davidson915
Sep 23, 2010 06:07 PM
