valve tap?
Old Nov 25, 2009 | 12:08 AM
zxwut?'s Avatar
zxwut?
valve tap?
I've got a loud tap from the passenger side of the engine, closest cylinder to the firewall. It goes away after the engine warms up and drives for a couple of minutes. Does it sound like I need to adjust valve lash or a bad lifter?
Old Nov 25, 2009 | 03:55 AM
lew52's Avatar
lew52
Not sure what motor you have or what the oil pressure is . The valves are not adjustable. Sounds like a lifter but could be anything from a worn cam , push rod , rocker arm , low or no oil press at start up , bad oil filter , cloged oil pick up screen....Lew
Old Nov 25, 2009 | 06:40 AM
BigSix1's Avatar
BigSix1
Or possibly an exhaust leak?
