water pump removal help
Old Nov 24, 2009 | 01:05 PM
valley2307's Avatar
valley2307
Cool water pump removal help
please help.how do you remove the fan clutch shaft from the end of the water pump.i'm at my wits end with this.what is the trick to keeping the pulley from spinning while turning the bolt.i've been at this for 3 hours.thanks
Old Nov 24, 2009 | 03:08 PM
Omahastro1's Avatar
Omahastro1
When the belt won't hold it I use a strap wrench. I have not replaced one on a 5.4 yet does it have the 4 bolts/nuts or does it thread on the waterpump shaft? Either way if you can't get the fan side to stay still with the fan belt use a strap wrench. The strap wraps around the pulley so it will keep it from turning.
Old Nov 24, 2009 | 03:42 PM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Former Vendor
make model and year and a vin and send me your email.
I have a little time today so I could email you the shop manual on how to do this.
ed
Old Nov 24, 2009 | 04:40 PM
valley2307's Avatar
valley2307
2000 expedition 4.6 vin#1fmru1661yla32345 email -rhs11510@yahoo.com thank you very much ed
Old Nov 24, 2009 | 04:41 PM
alloro's Avatar
alloro
Originally Posted by Omahastro1
does it have the 4 bolts/nuts or does it thread on the water pump shaft?
Both actually. There is the big shaft nut (which is reverse threaded) then once that is off there are 4 bolts holding the pulley to the water pump.
Old Nov 24, 2009 | 04:42 PM
alloro's Avatar
alloro
Originally Posted by valley2307
I'm at my wits end with this.
You do know that big shaft nut is reverse threaded...correct?
Old Nov 24, 2009 | 04:45 PM
valley2307's Avatar
valley2307
the big problem is trying to keep the pulley from spinning theres not much room for a strap wrench.does anyone know what size wrench for the shaft nut
Old Nov 24, 2009 | 04:46 PM
Parts Guy Wyatt
Former Vendor
SENT.
let me know when you get it.
ed
Old Nov 24, 2009 | 04:56 PM
alloro's Avatar
alloro
Places like Advance Auto and Autozone rent the special tool kit to remove it. The tool kit comes with the pulley holder and the wrenches to fit the nut. I think it's a 32mm (1-1/4") wrench that you would need.
Old Nov 24, 2009 | 05:23 PM
valley2307's Avatar
valley2307
thanks ed,i got it but it only goes as far as to tell you how to unbolt the pulley not how to keep the pulley from spinning when trying to remove the fan shaft
Old Nov 24, 2009 | 05:27 PM
valley2307's Avatar
valley2307
the new pump came with a protective cap over the threaded end of the end of the pump.i unscrewed the cap to remove and it was not reverse threaded
Old Nov 24, 2009 | 05:53 PM
Parts Guy Wyatt
Former Vendor
hmmm, sent two emails did you get both?
Old Nov 24, 2009 | 05:56 PM
valley2307's Avatar
valley2307
i did get both they were the same
Old Nov 24, 2009 | 06:08 PM
valley2307's Avatar
valley2307
my mistake ed they were different.looking at both of the special tools your supposed to use the large wrench fits on the shaft nut but i dont understand where the small crows foot wrench fits in
Old Nov 24, 2009 | 08:01 PM
alloro's Avatar
alloro
Sorry about that, I guess I got it confused with Chrysler which uses the revered threaded shaft.
