Sponsored by: Real Truck
Brake Controller
Old Nov 24, 2009 | 09:02 AM
abrahamseven's Avatar
abrahamseven
Brake Controller
I have a 2005 Super Duty with the Tow package and need to install a Trailer Brake Controller. I want to use the genuine ford or do they make an after market that will plug into the existing wiring? any information will be helpful. I looked on the official ford parts guy web page but come up empty handed.
Thanks
steve
Old Nov 24, 2009 | 10:42 AM
toypuller's Avatar
toypuller
Get a Prodigy controller. Great unit right out of the box.
Prodigy makes an adapter that is a direct plug in to the wiring harness under the dash.
15 minute install if you take your time.
http://www.etrailer.com/pc-BC~90185.htm
http://www.etrailer.com/p-3065-p.htm
Old Nov 24, 2009 | 10:47 AM
bpounds's Avatar
bpounds
+1 on the Prodigy.
IMO it's not worth retro-fitting the Ford built-in unit. But it can be done for somewhere between $400-$600. It requires the brake controller, a new brake master cylinder, and a trip to the dealer to have it turned on in the truck PCM. A few guys here have done it, if you search for their threads.
If you do it, and don't already have the upfitters, put those in at the same time. They are easy to do.
Old Nov 24, 2009 | 11:32 AM
1975StroppeBaja's Avatar
1975StroppeBaja
+2 on the Prodigy. Works like a champ. I bought the cable that adapts directly from the controller to the plug behind the dash. Install was a snap.
