Offroad & 4x4
rear lift questions (long post)
Old 12-01-2009, 09:17 AM
mark a.'s Avatar
mark a.
mark a. is offline
Why not just weld the 2 blocks together, making it into one solid block ?
Old 12-01-2009, 11:19 AM
Rcmgiasson's Avatar
Rcmgiasson
Rcmgiasson is offline
The 2 blocks are made of different material. The stock one is cast and the procomp on is aluminum and this will not solve my centering problem. I've already started on the fabed blocks and it looks like its going to turn out fine.
Old 12-01-2009, 01:00 PM
Prozon's Avatar
Prozon
Prozon is offline
I don't think welding blocks together is a good idea anyways.. even if you COULD.
Old 12-01-2009, 06:28 PM
79Ford4x4's Avatar
79Ford4x4
79Ford4x4 is offline
how about some pictures so we can see what your doing.
Old 12-04-2009, 12:14 AM
Rcmgiasson's Avatar
Rcmgiasson
i'll post some pics when its all done.
Finished the blocks tonight, ended up going with a 5 degree taper and offsetting the center pins 5/8's of an inch. Putting them in tomorrow, hopefully everything works out. Now just for the traction bars themselves.
Old 12-06-2009, 12:58 AM
fishmanndotcom's Avatar
fishmanndotcom
fishmanndotcom is offline
Originally Posted by Rcmgiasson
http://www.oneupoffroad.com/ouoproducts/tractionblocks.html
thats a killer idea/take on lift blocks! they sure look the safest i have seen. with real tall blocks i would have to look into a trac bar system but i like their idea!
-cutts-
Old 12-06-2009, 01:12 AM
Prozon's Avatar
Prozon
Prozon is offline
I like the design of the block.. but some of the things they say.. just seem stupid.
Reality is aftermarket lift companies have been using stacked blocks for 20 years. 60% of lifted trucks driving around every day have stacked blocks in the rear.
I've never seen an aftermarket lift that actually gives you two blocks and tells you "Here you go, just stack them!" And 99% of the trucks I have seen do not have stacked blocks. Yet they claim 60% of lifted trucks have them? I wonder how they came up with that number.
They are also kind of discouraging you to do spring lifts or add-a-leafs..
Reality is a 6” or 8” “All Spring” lifts eliminates the rear bump-stop and the overload system. With no overload and no bump-stop what stops the tire from hitting the fender at bottom out?
I think the idea behind 6" or 8" spring lifts is to space the tire farther away from the fender. You know, making it a little hard to rub!
Reality is a 2” Add-A-Leaf rides really harsh. They move your axle 2” from the rear bump stop and the overload system. They increase your ride height but not your bottom out protection. So the bigger tire you installed could go up and hit your fender.
Okay, but if you had leafs stacked to the height of one of those blocks, i'm sure you wouldn't be rubbing your fenders.
I think the block looks decent, but they should probably advertise it without bashing every other kind of lift.
BIGTRUCKBIGRV
6.7L Power Stroke Diesel
05-13-2015 05:03 PM
BIGTRUCKBIGRV
05-03-2015 09:23 PM
we287gn
02-24-2013 07:41 PM
BigNisTexas
02-06-2012 08:09 PM
rangermike
01-20-2011 08:40 AM
Quick Reply: rear lift questions (long post)
