1978 - 1996 Big Bronco
new question about diff shudder
Old Nov 22, 2009 | 01:23 PM
tazf250's Avatar
tazf250
if the rear diff has the wrong fluid in it, like no friction modifier could that cause shudder under power?
Old Nov 22, 2009 | 01:37 PM
Kemicalburns's Avatar
Kemicalburns
depends, what fluid is in there? should be 80-90w and friction modifier should only be needed if there is a limited slip out back. no limited slip no modifier necessary.
Old Nov 22, 2009 | 02:18 PM
tazf250's Avatar
tazf250
it does have limited slip rear diff
Old Nov 22, 2009 | 04:04 PM
greystreak92's Avatar
greystreak92
LS without friction modifier will cause the clutches to glaze over and could cause noise or vibrations at times when the clutches would normally engage.
