tempature gauge quit working???
Old Nov 21, 2009 | 03:37 PM
Pitchfork87's Avatar
Pitchfork87
my tempature gauge stopped working all of the sudden cant seem to figure it out.
anyone got any advice
Old Nov 21, 2009 | 05:14 PM
Hussler's Avatar
Hussler
Check the wire connection at the sensor. It's on the HPOP reservoir. Poor or bad wire connection there would result in the gauge indicating cold always. That wire goes directly to the gauge and no where else.
Edit: I should of said just below and in front of the HPOP on the water pump .. duh.
Old Nov 21, 2009 | 06:04 PM
Pitchfork87
no luck yet
warm engine up and check fitting even played around with it. Do you think the sensor might have gone bad
Old Nov 21, 2009 | 08:26 PM
joe_13894's Avatar
joe_13894
You can ground the wire at the sensor
With the wire grounded to he block with the key on, the gauge should go full scale. If it does it's the sensor, if it doesn't the wires to the gauge are bad or the gauge is bad.
Old Nov 21, 2009 | 10:15 PM
95_Dually's Avatar
95_Dually
Good post Joe. This should narrow it down for him.
