Motor Mounts
Old Nov 21, 2009 | 12:29 AM
BSCowboy's Avatar
BSCowboy
Motor Mounts
On a 1975 F-150 with a 390 which motor mount is larger the driver's side or the passenger's side? They are not the same size. One is significantly larger.
Old Nov 21, 2009 | 07:18 AM
BSCowboy's Avatar
BSCowboy
No one has any input on this matter?
Old Nov 21, 2009 | 07:24 AM
pidaster's Avatar
pidaster
I do believe the drivers side is the larger mount. When I put some britches on I'll go check and if I'm wrong I'll repost with correct info. The cut out on the cab for the tranny should be slightly offset as well. I believe it is a little toward the passenger side.
Old Nov 21, 2009 | 07:42 AM
BSCowboy's Avatar
BSCowboy
Thanks, I appreciate that.
While replacing the motor mounts on my engine I removed the mounting brackets. When I put everything back in my engine sets crooked in that if you are looking at the front of the truck it's slightly favoring the passenger side. It's not twisted, rather it's setting slightly off center.
It appears that someone at some point hit something rather large and bent the twin i-beam system. I am curious as to weather this is causing my engine to be slightly off center or could I have put the motor mounts brackets on incorrectly. Also, I guess if this is the case a frame straightener is the only solution.
Old Nov 21, 2009 | 11:34 AM
chubrock108's Avatar
chubrock108
The Driver side motor mount bracket is significantly larger on my truck. I have a 74 F250, but I'm sure it's the same as yours. I believe the motor mounts themselves are the same size just slightly different shapes.
Old Nov 22, 2009 | 10:33 PM
pidaster's Avatar
pidaster
That is correct. I misread the original post. I was thinking mount brackets because that has been on my brain.
Old Nov 23, 2009 | 06:06 AM
BSCowboy's Avatar
BSCowboy
Thanks ya'll
