Inherent problems with 1984 Diesel engine?
Old Nov 20, 2009 | 04:13 PM
jdhunt69's Avatar
jdhunt69
I'm considering buying a 1984 Ford Econoline 350 XL Class C RV with a rebuilt diesel motor - not sure what kind - It has a leaking head gasket but is not leaking into the engine, just leaking out radiator fluid. The diesel was 'overrevved' at 45,000 miles and rebuilt. It now has 50,000 or so on the engine (95,000 or so on the RV) and developed the head gasket prob recently. My question is: what kind of problems am I getting with this engine? Is the head gasket part of a factory flaw? Or would that have been taken care of during the rebuild and this is something new? What is the worst case scenario with this head gasket?
Thanks!
Old Nov 20, 2009 | 08:00 PM
fellro86's Avatar
fellro86
What typically causes head gasket problems on these is oil vapors from the CDR valve, which does the job of a PCV valve. The back cylinders get the oil from this, making them run hotter, stretching the head bolts, and burning out the head gaskets. Keeping the CDR clean takes care of this problem generally. It is the tin can looking thing on the backside of the intake. I don't see how it could have been over revved when the injection pump will limit how fast the motor can run.. The early 6.9 can possibly develop a crack in the block around the block heater if it gets used as the casting was thin there. Don't use the block heater there and there are no concerns about that. (As long as it isn't already a problem...)
Old Nov 20, 2009 | 10:40 PM
Franklin2's Avatar
Franklin2
Make sure you have a 6.9. They may have swapped in a 7.3 which looks exacty the same, except the rebuilt 7.3's have sleeves in the cylinders. These are famous for sliding down and causing head gasket leaks.
Psychowolff1
13
Jul 27, 2015 12:31 AM
Psychowolff1
Jul 25, 2015 02:37 AM
genscripter
19
May 10, 2015 03:57 PM
MrMagic
Aug 18, 2014 06:30 AM
Ironpants
36
Apr 26, 2014 08:44 PM
