F250 Axle
Old Nov 20, 2009 | 03:23 PM
Atwatead's Avatar
Atwatead
F250 Axle
Does anyone know if the left front axle housing from a dana 44 HD IFS is the same as a Dana 50? I have a 94 F250 with the Dana 50 that is cracked and I have access to an 87 F250 with the Dana 44 HD and was wondering if they were the same housings. The housings no longer available from Ford and aftermarket are only for 1/2 tons.
Old Nov 20, 2009 | 05:29 PM
andym's Avatar
andym
The Dana 50 has a larger ring gear than the Dana 44, so I would assume that the left front housing where the gears are would be larger. However, I don't know for sure. Can you get some measurements and compare?
Old Nov 20, 2009 | 07:01 PM
Ford6.02005's Avatar
Ford6.02005
They are definitely different- also the knuckle and lower ball joint are different between them. I have seen many cracked Dana 50 LH axle housings-usually trucks with large snowplows! Also I don't recommend trying to weld a cracked housing-usually they crack again next to the repaired area!
