Header Questions
I've got the engine out, and I'm going to overhaul the gaskets. The motor runs fine, so a complete rebuild is not necessary at this time.
I'm likely going to install a set of headers in place of the exhaust manifolds. I've got some questions though, hoping to tap the brain trust for some insight.
When it comes to hedder coatings, what's the good to best ranking of paint vs thermal vs ceramic? My guess is good = thermal, better = paint, and best = ceramic? Is that right, or is thermal better than paint?
For a basically stock, occasional driver/hauler, but over-all "Nice" (not a shower) truck, should I spend the bucks on ceramic? I'm trying to keep the budget to a modest figure, but we all know saving money can end-up costing more.
Also whats the preferance on bolted flange, ball/socket, or slip fit collectors?
I'm leaning towards;
Hedman Elites, 14Ga, thermal coated, ball and socket. $337
-OR-
FlowTech, 18Ga, Ceramic, bolted flange. $313
Thoughts?
I'm thinking of using the Headman Elites on my next project. They are more expensive, but they seem like a better quality piece with the thicker flanges and ceramic coating.
I would suggest something with a 1 piece flange (where it bolts to the head) the others can warp from the heat and be a real (you know what) should you ever have to take them off for any reason. The bolt holes can be difficult to line up when you go to put them back on.
