Did you look for vacuum leaks, spray carber cleaner and look for an idle change. Can you do a fuel pressure test. I think you want about 60 but check that. Have you run some injector cleaner. Did you scan the obd?(I know you said no codes but I am wondering if you meant the cel never came on) Have you cleaned the maf and the iac?
Not sure how to check for vacuum leaks and I don't have anything to check the fuel pressure with. I haven't done the MAF or the IAC but I did do the injector cleaner and yes I scanned but I might do that again.
You visably look for broken or disvonected hoses etc. Then you take. Carb vleaner and spray it on hoses and gaskets etc. If there is a leak the carb cleaner gets sucked onto the leak and changes the idle.
