Sponsored by: Real Truck
Please help!!!!!!!!!!1
Old Nov 19, 2009 | 04:22 PM
jerrycolwart's Avatar
jerrycolwart
2009 f-250 cabella's edition....
Currently have Toyo 33x12.5-20, tires look very small on the truck.
The truck has a factory 4" lift.
Can I fit 37x12.50-22 without the front rubbing?
If not what is the max hieght I can go with?
Thanks
Old Nov 19, 2009 | 04:30 PM
Ace!'s Avatar
Ace!
I don't believe the factory offers a lift, maybe the dealer does. A 37" taller tire will be two inches closer to everything (2" on each side of the hub). You've got 4" taller, but not necessarily on both sides of the hub. What I'd start with is a tape measure and measure two inches from the edge of your current tire toward anything that might rub. Can you get two more inches outside of your current tire toward the bumper or fender?
Old Nov 20, 2009 | 03:48 AM
jerrycolwart
Thanks
Looks like it will be close....Thank you for the help....
Old Nov 20, 2009 | 10:58 AM
rotun's Avatar
rotun
Reads ***** rules!
I have a DR 7" + 1" TEI lift, a total of 8" lift and am running 37's. They are really close on the plastic under the front bumper edges, I havn't trimmed them yet as they only rubbed once in awhile when turning into a driveway with the suspension loaded from being on the brakes. I have since trained my foot to let off the brake when turning over bumps and I don't get any rub now. I don't believe a 4" lift will accomodate 37's, 35's definitely.
Old Nov 20, 2009 | 12:36 PM
superdutyduck's Avatar
superdutyduck
i can put 35's on my truck without a lift and they rub a little. i think you'ld be safe if you have a 4" but you should call your local 4X shop just to be safe.
Old Nov 20, 2009 | 03:25 PM
rotun's Avatar
rotun
Reads ***** rules!
Old Nov 20, 2009 | 03:30 PM
rotun's Avatar
rotun
Reads ***** rules!
