General Automotive Discussion
I've been negligent
Old Nov 19, 2009 | 12:38 PM
tseekins's Avatar
tseekins
Veteran: Coast Guard
Exclamation I've been negligent
After my little cracked tire episode I decided to do a full inspection of my entire inventory to include spare tires.
Everything else is fine but what I discovered was my space saver spare in my Taurus only had, get this....4.00 PSI in the tire! The tire calls for 60 PSI! How stupid am I!
Live and learn so they say and thank GOD I didn't need the spare.
So, for those of you as negligent as me, check your spare tires please.
Tim
Old Nov 19, 2009 | 09:42 PM
bigdaddyII's Avatar
bigdaddyII
That is done every other week along with the rest of the tires.
Old Nov 19, 2009 | 10:09 PM
mercman86's Avatar
mercman86
I gotta check mine on my truck, going to florida in a week would hate to be stranded with a flat and a flat spare! I remember getting a flat in my 1984 Olds Ciera in the middle of nowhere Ohio and my spare had just enough air in it to keep the rim off the ground! The tire and jack had never been used and probably sitll had the air from the factory in it!
Old Nov 20, 2009 | 05:51 AM
hanklin's Avatar
hanklin
It could be even worse if it happens in the rain or snow and you have no cell phone working. Good heads up Tim. Check mine when sun comes up
Old Nov 20, 2009 | 07:57 AM
bigdaddyII's Avatar
bigdaddyII
I love you avatar hanklin.
Old Nov 20, 2009 | 09:33 AM
preppypyro's Avatar
preppypyro
For what its worth Tim, you dont need 60 psi in your tires (spare or on your car), max I would put in is 35 psi for use on the car!
Old Nov 20, 2009 | 08:52 PM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
^what he said^
Check air pressure in your spare once a month (along with the rest of your tires!)
Old Nov 21, 2009 | 04:46 AM
tjc transport's Avatar
tjc transport
i ain't rite
space saver spare tires have very poor sidewalls. that is why they call for 60 psi inflation. with lower pressure, the sidewall will collapse.
that is also why they are a one time use of under 60 miles.
Old Nov 21, 2009 | 09:43 AM
preppypyro's Avatar
preppypyro
Good call Tom, I didnt even catch that it was one of those "doughnut" tires.
My bad I misread and thought it was a full spare!
Old Nov 21, 2009 | 12:31 PM
BigF350's Avatar
BigF350
FTE Emeritus
Likewise !
Old Nov 21, 2009 | 01:54 PM
tjc transport
i ain't rite
i figured that, and that is why i tossed my smartassed comment in the mix.
Old Nov 21, 2009 | 01:55 PM
shorebird's Avatar
shorebird
DO NOT, I repeat DO NOT check your spare!! There is a tow truck driver out there who needs the money he will earn from your neglect.
Old Nov 21, 2009 | 02:59 PM
mymechanic'sanidiot's Avatar
mymechanic'sanidiot
Coulda been worse. Could be like the Focus the past few years. The "standard" spare is a can of Fix-A-Flat. You have to pay for the doughnut. That is cheeeeeap. I know the Focus is the bottom end car but come on.
Old Nov 21, 2009 | 03:00 PM
mymechanic'sanidiot
I was not aware that the doughnuts were only supposed to be used once. Good reason to go ahead and pay for a full-size spare.
Old Nov 22, 2009 | 01:50 PM
tseekins's Avatar
tseekins
The full size spare will not fit in the nifty little storage area that that Ford provided on the Taurus Wagons. Just enough room for the donut tire, tire iron, sissor jack and a jumper cable.
BTW, the sidewall says to inflate to 60 psi.
Tim
