exhaust question
Old Nov 18, 2009 | 07:53 PM
basspro620's Avatar
basspro620
exhaust question
i'm getting my exhaust completely redone. what should i do to get the loudest/deepest sound possible?
Old Nov 19, 2009 | 12:36 PM
okiepc1's Avatar
okiepc1
Without knowing what engine you have I will tell you what I did on my 85 F150 302.
I had cat. back duals put on with a single muffler, comparable to the big name exhust, it sounded like a friggin PRIUS OMG!, so I went back, had the cats. removed, went with true duals, I got the sound I wanted, a good low rumble at idle that gets a little better under load, no poppy cracky crap, I like it.
okiepc1
Old Nov 19, 2009 | 01:21 PM
basspro620's Avatar
basspro620
mine's a 302.
Old Nov 19, 2009 | 04:42 PM
okiepc1's Avatar
okiepc1
well if you can get away with it where you live, remove the cats. and go with a good sounding mufflers, your shop can tell you whats what.
Old Nov 19, 2009 | 08:52 PM
displacement4me's Avatar
displacement4me
Youtube can help you out a lot. Flowmaster 40, 44's, glasspacks etc etc etc. The searches are endless. This helps give a name to sounds you are after to approach your shop with.
Old Nov 19, 2009 | 11:12 PM
basspro620's Avatar
basspro620
well my current set up is stock manifolds, with dual glasspacks coming out behind the rear wheels. i have 2 40 series flows that were given to me off a 69 mustang. so i'm gonna put the flows in place of the glasspacks. but as far as headers, and dumping them at the axle or runnin 'em out the back, i'm stuck. i need to have my whole exhaust redone because the pipe i have is dryrotted. so i'm thinkin 2&1/2" pipe. what would an h pipe/x-pipe do for me?
Old Nov 20, 2009 | 10:21 AM
Redneck1465's Avatar
Redneck1465
Personnally I would do the flowmasters with it exiting out the back it gives it a little deeper growl in my book. I would just do a y pipe if it was me. I have had several trucks with that setup and I really like it.
