SEIC
Old Nov 18, 2009 | 05:16 PM
Blackwaterforge's Avatar
Blackwaterforge
SEIC
Hooked the SEIC (orange wire) up to the # 4 AUX. Everything seemed strait forward. But it dosn't work. I have power to the orange wire when the # 4 switch is on.
Old Nov 19, 2009 | 02:34 PM
bpounds's Avatar
bpounds
Make sure your parking brake is set. Transmission must be in PARK. Foot must not be on the brake, which also means the brake switch must be operating properly.
You might also try switching over to the BCP wire, instead of SEIC.
I see from your profile that you have an '05. So you used this guide, right?:
http://www.thedieselstop.com/content...%20High%20Idle
It is different than the '04 and earlier trucks.
This might help too:
https://www.fleet.ford.com/truckbbas/non-html/Q108.pdf
Old Nov 19, 2009 | 03:49 PM
Blackwaterforge
Thank You for your reply. Yes I printed the diagram and followed it exactly.
Old Nov 19, 2009 | 05:11 PM
tazo's Avatar
tazo
https://www.ford-trucks.com/forums/3...ml#post2327760
Since I have a manual trans there is a different color wire in the bundle that I had to use. If you check through this thread it will describe what wire is needed for the high idle. Make sure the e brake switch works. Put the truck in gear with the e brake on and a dinger should go off warning you that the brake is still on.
Old Nov 20, 2009 | 07:42 AM
Blackwaterforge
Tazo
Thank You for your reply!
There is no chime when you leave parking break on.
Old Nov 20, 2009 | 09:17 AM
bpounds's Avatar
bpounds
Originally Posted by Blackwaterforge
Tazo
My truck does not ding when the parking brake is on and I put it in gear. I don't know where tazo got that. The older trucks do not do that. But there is a light on the message center, and his point is well taken. If the parking brake switch is bad, the PCM won't know that the brake is on. So make sure you have the RED brake indicator on the dash.
Obviously the parking brake switch and the service brake switch must be functioning properly or this might not work.
Do you have a manual tranny, or automatic?
Old Nov 20, 2009 | 11:08 AM
Blackwaterforge
I Have a manual. Parking brake light works properly as do brake lights.
Thank Y'all for your replies!
Old Nov 20, 2009 | 12:04 PM
dchamberlain's Avatar
dchamberlain
Read this PDF file carefully...
It indicates to me, under the resistor chart on page 8, that the manual transmission REQUIRES a 43K ohm resistor. The diesel engine diagram on page 10 shows that resistor going between the PTO_VREF (orange/red) and PTO_RPM (orange/yellow) wires.
Another option would be to use the Battery Charge Protect wire (purple/lt green) instead of the PTO wire (Orange).
Old Nov 20, 2009 | 12:14 PM
bpounds's Avatar
bpounds
And, unless you are actually going to use a PTO device, the BCP is a better way to go. Why lock up the TC for no reason?
Majic31
Jan 18, 2017 08:37 PM
Tuxedo Scorpion
6.7L Power Stroke Diesel
17
Sep 20, 2014 05:54 PM
kblazk
Mar 11, 2013 09:56 PM
JohnD333
15
Oct 3, 2010 01:41 PM
