Sponsored by: Auxito
bad bushings
Old Nov 18, 2009 | 12:30 PM
98F250's Avatar
98F250
bad bushings
My '98 250 has the load-leveling suspension and trailor towing package with the anti-wind bars (as referred to in the shop manual) mounted at each side rail and rear differential axle housing. The rubber bushings have failed to the point of metal on metal, causing thumping/knocking noises on bumps, etc. Big Ford does not make these parts anymore...at least that is what I have been told. Attempts to find aftermarket parts is a dead-end. Any info on how to find either the whole bar assembly or the rubber bushings for each side would be much appreciated.
