I am hearing a growling noise from the rear when I turn. Only when I am hauling a load. Started after I sunk the truck in the lake and flooded the rear end with water. Ended up driving about 500 miles before I realized it. Sounds pretty bad. I changed the fluid but I think there is something else going on.
Most common load for the truck is about 10,000 lbs (5th wheel camper). Most severe load, about 28,000 lbs (gooseneck w/hay).
With 140,000 miles on the truck, could the bearings be out?
