mileage blues
So, is this normal? I put on a 4 inch straight pipe(which should be better mileage) . . . I've got 305-75 load range E tires, inflated around 54psi or so. I put in an aftermarket filter, it is not K&N, but it is an equivalent setup that is nicer I think. S&N might be the manufacturer?? I have the superchips tuner, but right now the truck is NOT TUNED . . .
Does anyone think I should tune the truck and see what difference it makes?
Oh yeah, I've had a HPOP leak for the last 3 months. Finally decided to try and fix it myself. I did that yesterday . . . still leaking today, but not as much . . . I'm thinking some oil is still left on top of the engine that is still dripping down looking like a rear seal. Could the HPOP have any affect on the mileage?
Thoughts, ideas and opinions would be greatly appreciated. Thanks.
Is it a 4x4?
I usually get right around 14 or a little higher in the city, but you should see some improvement on the highway, 4x4 or not.
Check for boost leaks around the I/C boots and on the up pipes. There are a few other things people will list that I have forgotten. Rough day today!
Tuning it would help eh? Ok. I have the tuner, but I've been scared to because of all the talk I read about with exhaust temps and such. I know I have the right exhaust to tune it. (4 inch down pipe all the way to the 5inch tail pipe)
And I have a great air filter. And to boot all that, I have the exhaust temp gauge and the turbo boost gauges . . . just haven't installed them because I don't know how and I don't trust the local Mexican repair shops to know how on my diesel.
So, do you think it is safe to tune it and run it conservatively without my gauges being installed yet? And, do you think I can install the gauges myself without trouble?
So basically guys with 4x4s and big tires are claiming 17-19 with these rigs? I've seen some people claiming it, and I don't really see how it is possible.
Lastly, it was mentioned the I/C boots and the up-pipes. How would I check those and what exactly would I be looking for? No one has made a comment on the HPOP leak factoring in, so can I ignore that as dragging any mileage out of my truck?
Oh yeah, any thoughts on going synthetic in my transmission and my differentials? Seems to me that could show a sig difference.
Thanks a ton.
Last edited by megawatt00; Nov 18, 2009 at 06:18 PM. Reason: Remove drug reference.
The best I have seen on the highway has been 17.25. This was done with a 4" open exhaust, a 6637 air filter and a DP on 80 eco.
And now that we are on winter blend.. I will be watching.
17.8 seems unbelievable . . . wow! I mean, the difference in a 285 and 305 tire isn't too much for most brands. But then again, your original mileage is about what I'm at.
I'll get back with any codes, and please advise on what the EBP is and how I would check it. Thanks.
Welcome to guzzle's Exhaust Backpressure Sensor Cleaning Maintenance Web Page
I run 315's with a front leveler and get between 16 and 17 mpg pretty much all the time. Mostly city driving with little hwy here and there. Check my signature for every thing I have done. Along with EBP, check some of the other regular culprits, fuel filter and leaky up pipes.
You will loose a mile or two with 305's mostly due to road friction and a we bit to air drag (larger frontal area). Lift will only hurt a tiny bit at 1.5" but it all adds up.
14 mpg around town is typical from what I have read and experienced. You best mpg improvement is allways the 2x4 fix. Stuff a 2x4 under you go pedal and you will see a 20% improvement and you will get the unique experience of being passed by a 67 vw micro bus on the hills. Not worth the extra mpg. These are HEAVY trucks that take a lot of juice to get up to speed, once you are there they are not bad, (my old 4.9 v6 f150 2x4 got worse mpg in town), but who wants to be passed by grandma?
Do a search for EBPV (exhaust back pressure valve). This is a valve designed to help warm your engine up to operating temperatures by creating backpressure at the turbo. When it is on in kills you engine efficiency and you motor sounds like a a jet engine with a cold. It is not supposed to engage under heavy load or when exhaust temps are above xyz. This valve is also a source of oil leaks for most of us which for some (self included) is the final straw to just gut the ebpv or delete the darn thing as it does not get cold enough to justify it's use.
There is a tube coming off the passenger manifold that leads to a sensor down by the fan pulleys that sometimes gets clogged. Do a search for ebpv sensor and you should find the step by step to walk you through it. Good luck and welcome to the site.
I cleaned my sensor, but replaced the tube. First cold morning today and my EBPV is only partially closing. The hiss, not the roar, is back!
I don't use synthetic anything, but only because I'm cheap. Next time I'm up for a major fluid change, I will probably swap to synthetic.
I haven't gotten over 18mpg in a LONG time. Usually mid 17's on highway these days, but I do have my bed cover off...never really thought about that, but I will be putting that back on this weekend anyways.
