Need help
Old Nov 17, 2009 | 07:17 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Need help
Hello every one. I know it's not the right forum but can you help.
About 1 month ago I had some rear end work done on the 08 F 450. They replaced a carrier bearing and a part of the eaton locker. At the time they said ever thing else in the rear end was good INCLUDING THE RING AND PINION GEAR. They had to re do all the shims and every thing in the rear end. Now 2,000 miles later the rear end is making a whining noise and I brought the truck back to them. Tonight I talked to them and they say it needs a new RING AND PINION FOR $1,800. How can a rear end go bad in 2,000 Miles????????
Sorry if I seem pissed but I am about to loose it.
Do you guys think that they messed up when they put it back together.
Nick
Old Nov 17, 2009 | 07:20 PM
rbaker6336's Avatar
rbaker6336
it shouldn't.They didn't set it up right,most likely too tight
Old Nov 17, 2009 | 07:21 PM
weekendwarriorfsw32
Master of Strokes
That's what I thought.
Old Nov 17, 2009 | 07:29 PM
megawatt00's Avatar
megawatt00
I have to agree with Ray here Nick they messed it up. It still be under warranty shouldn't it?
Old Nov 17, 2009 | 07:37 PM
Kwikkordead's Avatar
Kwikkordead
X3, they set something wrong.
Old Nov 18, 2009 | 08:54 AM
milleroutdoors's Avatar
milleroutdoors
Nick I am with everyone else here, the repair tech, set it up wrong. Period..
Old Nov 18, 2009 | 09:49 AM
just another truck's Avatar
just another truck
AGREED, they did not space the ring and pinion enough, or to much. Good Luck with this Nick. this happened to me once, and I got no where with it, I reported it to the BBB but still nothing came from it.
