Starting problems
Old Nov 16, 2009 | 02:31 PM
dandano's Avatar
dandano
Starting problems
This is my first post, hope someone can assist me with a cranking problem. I have a 1987 ford-150 six cylinder (4.0 L), 4 speed with a granny gear with approx 20,00 miles on a replacement engine. It starts fine the first time however, after driving for at least 15 minutes or more and the truck is turned off, It will not restart unless the truck sits for about 15 minutes or longer. this problem existed with the original motor and the replacement engine. I have replaced the starter twice and the alternator once and the battery twice along with new battery cables. In addition, I have installed a heat sheild on the starter and still experiencing the same issue. When experiencing this problem, the starter sounds like the battery is low or dead even with a new battery. As this is my first post if I have left any
information out then please let me know and I will add any information needed. I thank all in advance for any help provided.
Old Nov 16, 2009 | 03:08 PM
subford's Avatar
subford
Where are you running the large NEG (-) post battery ground cable from the battery to?
Old Nov 16, 2009 | 03:20 PM
vancouver island's Avatar
vancouver island
If I am right check your starter relay that sounds like the problem. it is on the fender wall passanger side.
Old Nov 17, 2009 | 07:39 AM
dandano's Avatar
dandano
I have not considered either option, they both are on my bucket list for today. Thanks, I advise. dandano
Old Nov 17, 2009 | 08:01 AM
dandano's Avatar
dandano
starting prblems f-150 91987)
The large battery cable (ground) is attached to the vehicle frame. dandano
Old Nov 17, 2009 | 08:14 AM
Bryan Bennett's Avatar
Bryan Bennett
The big cable---it should go to the engine ------the engine sets in rubber mounts-so it is isolated from the frames ground to some degree.
There should also be a ground from the battery to the frame/body and the engine should have a ground wire or 2 going to the body
subford's Avatar
subford
That is wrong and may be your problem.
The large ground cable is to be bolted to one of the starter mounting bolts on a 4.9L engine.
There also has to be a small wire (10 GA) from the battery NEG (-) post to the body (not the frame).
You do not have to run a ground to the frame unless you are pulling a trailer.
Old Nov 17, 2009 | 01:26 PM
dandano's Avatar
dandano
It appears that the ground cable that is bolted to the frame was done at the factory, but not positive. If I understand right, by possibly removing the ground cable from the frame and attaching it one of the starting mounting bolts might solve my problem. If so, I'll give that a shot.
Old Nov 17, 2009 | 02:39 PM
subford's Avatar
subford
Yes that is correct, try it.
The factory would have ran the ground cable to the starter mounting bolt for the engine and starting motor. But it would also have had a center lug part way down the cable that was bolted to the frame. This lug provided a ground if the truck should pull a trailer or if it had no rear bumper. The frame would then have provided a ground for the license plate lamp with that lug and also the trailer ground. The trailer ground was for the trailer lights and brakes.
There was also two other wires from the neg post of the battery, one to the body and another other one for the computer.
Old Nov 17, 2009 | 04:49 PM
dandano's Avatar
dandano
Upon closer observation, I did fnd that the ground cable was bolted to a center lug on the frame about half way to the starter and then another cable attached at the center lug, thus extending to the starter. I removed the connection lug, cleaned both connections to insure a proper ground. After a road test, I still had the same problem. However, I did notice that I have only one wire running from the neg post of the battery.
I did not replaced either of the cables in order to have one continous run to the starter, but would have no problem in doing so if you think it might help.
Old Nov 17, 2009 | 05:38 PM
jr32560's Avatar
jr32560
the ground cable itself may be bad-check it thoroughly~ they have been known to go bad and this sounds like a possible cause of your problem
Old Nov 18, 2009 | 11:18 AM
dandano's Avatar
dandano
First of all, thanks to all for assisting me with this issue. The cables have not been changed in awhile, I will do that, thanks. In curiosity, does anyone know or have a suggistions or as why cranking would be an issue after the truck has been driven as opposed to cranking it when it was cold or sits for about 15 minutes?
Old Nov 18, 2009 | 11:40 AM
quicklook2's Avatar
quicklook2
has to do with the resistance when hotter.
