93 F250 Problems
Old Nov 16, 2009 | 12:54 PM
BigRickD's Avatar
BigRickD
Question 93 F250 Problems
I drive a ford F250 it has the 460 in it. It is having some problems, when i put my foot on the accelerator it bogs down and doesn't want to go anywhere. although it still goes just doesn't do it like it used to! any advice?
Old Nov 16, 2009 | 02:06 PM
DBGrif91's Avatar
DBGrif91
I'm actually working on troubleshooting the same problem on my 91 F-150. You can start by pulling codes- see fordfuelinjection.com for how to info. You might also want to read my progress thread if you want to follow along with my progress. You can find it here:
https://www.ford-trucks.com/forums/9...g-problem.html
Old Nov 16, 2009 | 07:47 PM
Dancingchicken's Avatar
Dancingchicken
Had an 85 Bronco did the same thing. Ended up being a plugged cat converter. Took it apart and knocked out some of the inards and it never gave me another problem.
Old Nov 20, 2009 | 12:18 AM
BigRickD's Avatar
BigRickD
alright thanks ill keep an eye on your thread and ill see what i can do about the cat. again thanks!
Old Nov 20, 2009 | 07:20 AM
Dancingchicken
Please understand that this could be caused by many things, cat converter is just one possibility. You should start troubleshooting this by pulling the codes as suggested.
