Aerostar Ford Aerostar
Chokey no worky
Old Nov 16, 2009 | 10:26 AM
oh2bnok's Avatar
oh2bnok
Chokey no worky
My choke stopped working on me and I just don't know where to start looking or what the fix might be. Would appreciate any help with this. The temperatures are dropping and I need to get it fixed a soon as possible.
Last edited by copper_90680; Nov 16, 2009 at 08:31 PM. Reason: Please, no selling in the forum
Old Nov 16, 2009 | 01:00 PM
96_4wdr's Avatar
96_4wdr
No Chokey on Aeroey. musty beey somethingy elsey.
maybe IACey?
what are the symptoms?
any PCM codes?
Old Nov 16, 2009 | 01:23 PM
oh2bnok's Avatar
oh2bnok
It isn't ideling up when started, used to but not eny mo. So it takes a few extra minutes to warm up and drive without stalling. Starts back up OK and when warm runs fine. All other bodily functions seem normal. I haven't checked any codes yet. So you say check the codes first, I can take it to AutoZone. Any code in particular associated with something easy to fix? Thx. Bill
Old Nov 16, 2009 | 01:24 PM
oh2bnok's Avatar
oh2bnok
Oh forgot to ask, What is IAC ?
Old Nov 16, 2009 | 02:27 PM
modularF100's Avatar
modularF100
Idle Air Control. It's near the throttle body.
Old Nov 16, 2009 | 03:14 PM
Pablo-UA's Avatar
Pablo-UA
I think on TB.....
Old Nov 16, 2009 | 03:33 PM
oh2bnok's Avatar
oh2bnok
Alright, Is this a pretty sure bet the culprit? It 's $63.00 at the ZONE.
Old Nov 16, 2009 | 04:06 PM
xlt4wd90's Avatar
xlt4wd90
Check to see if the IAC is working first; unplug it with the engine idling, and see if the speed drops. If so, it's probably working.
More likely the engine coolant temperature sensor is not working, so the EEC always thinks the engine is warm, so it's not applying the proper controls when it's cold. I'm not sure which one that is on a 3 liter.
Old Nov 16, 2009 | 04:10 PM
oh2bnok's Avatar
oh2bnok
I think I'll top of the radiator as it may be a bit low based on the temp surge today. Then pull the sensor off and clean it and then see what happens in the morning.
Old Nov 16, 2009 | 06:15 PM
96_4wdr's Avatar
96_4wdr
also check wiring plugin connections on ECT engine coolant temp sensor.
Under hood, center, upper engine area, rear of water outlet, mounted in intake manifold , the 2 wire sensor
AutoZone.com | Vehicle Selection | Year
Old Nov 18, 2009 | 06:05 PM
Aeroman59's Avatar
Aeroman59
Can also be Air charge sensor (ACT). Then there are worn (Bosch) plugs which will do that. When were last changed?
