frontend wandering
Old Nov 15, 2009 | 08:43 PM
auggieinks's Avatar
auggieinks
frontend wandering
Well this is my second try at try'n to find out why my frontend wanders when I hit a pothole. I took it back to the dealer and they said there is nothing wrong with it-AGAIN. But it still does the same thing and I'm wanting to correct the problem. I've replaced everything I can so it's got everything but new I-Beams and a slave cylinder. It's never been in an accident or abused so I'm not think'n anything is bent. I was going to get a dual steering stabilizer cuz they help my jeeps so well but can't cuz the f250 has a slave cylinder. Anyone got a clue as to how I can fix this?
Old Nov 15, 2009 | 09:17 PM
auggieinks's Avatar
auggieinks
Well guys please excuse my lack of knowing. I've just found out that there is no slave so no worries.
Old Nov 15, 2009 | 09:56 PM
4bars13stars's Avatar
4bars13stars
one thing that caused it in my pick is a bad tire.. but it was extremely bad with the 35's on it.. check for ANY improper wear in your front tires.. and another easy test.. take a good tire.. start on one and than go to the other side and see if that cures the problem..
Old Nov 15, 2009 | 10:04 PM
kermmydog's Avatar
kermmydog
So you have replaced the steering box?
Craig
Old Nov 16, 2009 | 12:47 AM
bghnkinf250's Avatar
bghnkinf250
It sounds like the I-beams have not been off? Have the pivot arm bushings been replaced?
Old Nov 16, 2009 | 01:40 AM
Ken Blythen's Avatar
Ken Blythen
If the steering box is out of adjustment, tightening it up makes a big difference - but everything else needs to be right first & there are specific torque settings/procedure to follow, to prevent early wear.
Old Nov 16, 2009 | 08:09 AM
bashby's Avatar
bashby
Usually the term "wandering" refers to a constant kinda looseness in the steering. When you say it only does it when you hit a pothole, does it dart off in one direction when you hit a bump? (bump steer) If thats the case, does it only do it when a certain side hits the hole?
BroncoMad
Feb 18, 2012 09:59 PM
Bullride_101
1983 - 2012 Ranger & B-Series
Feb 3, 2009 12:47 PM
red bud
Aug 30, 2007 08:45 AM
Boyd
Jun 29, 2005 03:24 PM
