300 in a fox body mustang ????
Not 100% positive but I don't think that the 300 will fit in a FoX body engine bay without serious modifications. The 300 will bolt up to the T-5 (same bolt pattern as the "small block" 8s, but the you'll be pushing that T-5 to it's limit with the torque that the 300 puts out.
Check with www.fordsix.com to make sure, they'll know more about trying it, most likely.
The 302 makes more torque at a slightly higher rpm than the 300, so the T5 isn't your issue. You may have to bash the firewall and reconfigure the radiator and accessory drives. Hood clearance and an oil pan will be issues.
Lots of work. You could swap the 302, and starting on Friday PM drive it to work on Monday after a Sunday morning shake-down run. Try to swap the 300 in there, it may never see the road again.
jmo, ymmv.
jmo, ymmv.
79-80 had a 3.3[250] I6. I had 1 of them. when I pulled the 6 to put in the 302, I had to change the motor mount assy struts and all. the 4, and the 8 take the same one. the 6 has the motor mount perches 18" apart. if it will clear the radiator, use that mount set up, and you should be ok. I have a friend with a 300 in a maverick. tight squeeze, but it's in there
Personally I think that all comes down to what your comfortable with fabricating!!
79-80 had a 3.3 [250 ] I6. I had 1 of them. when I pulled the 6 to put in the 302, I had to change the motor mount assy struts and all. the 4, and the 8 take the same one. the 6 has the motor mount perches 18" apart. if it will clear the radiator, use that mount set up, and you should be ok. I have a friend with a 300 in a maverick. tight squeeze, but it's in there
Fox bodied 1978/83 Fairmont/Zephyr's had 200's, as did 1979/83 Mustangs/Capri's, 1981/82 Granada's, 1983 (midsized) LTD's.
The last year for the 200 was 1983. The last car to have a 250 I-6 was the 1980 Granada, which is not a Fox body.
A Maverick/Comet engine bay is much larger than any Fox body, which was introduced in 1978.
