Doors
Old Nov 14, 2009 | 05:12 PM
OldBlue66's Avatar
OldBlue66
Doors
I have a 66. The doors, hinges and cab were all seperated to sand blast and paint. I have worked for hours trying to get them to line up with no luck. Does anybody have any tricks for putting the doors back on. Any help would be great.
Thanks
Old Nov 14, 2009 | 07:45 PM
macgiobuin's Avatar
macgiobuin
Those doors are a real pain in the keester to get put on straight/flush. The only suggestions I have is be patient and keep trying. I wish I knew of a shortcut.
Old Nov 15, 2009 | 05:35 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Make sure the vehicle is parked on hard level ground when removing/installing doors.
If the doors were removed when the vehicle was parked on soft ground, on a slope or was on jackstands, re-hanging the doors can be a real b!tch.
Old Nov 15, 2009 | 02:13 PM
OldBlue66's Avatar
OldBlue66
Thanks. I will keep trying. You have to wonder how they did it on the assembly line.
Old Nov 15, 2009 | 08:35 PM
ol yeller's Avatar
ol yeller
If you were just beginning I drilled 2 1/8 inch hole in each side of hinge thru the metal. Then used line up dowels to line back up.
Old Nov 17, 2009 | 05:39 PM
OldBlue66's Avatar
OldBlue66
I already took them off. I did finally got the drivers side door on. Now onto the other side. Thanks everyone for your help.
