Steering box
Old Nov 12, 2009 | 09:15 PM
unibody62's Avatar
unibody62
Steering box
After I went through my steering box on my 62 ands replaced seals and everything, it still seems to be seeping oil from it. I think it is actually coming from the top, where the big adjustment nut is. Is there some way to seal that?
Old Nov 14, 2009 | 09:10 AM
59INA40's Avatar
59INA40
You might want to consider grease instead of oil for your steering gears. I used this in my '40 and recently in my '65 with great results. Steve
http://www.penriteoil.com.au/product..._box_lubricant
Old Nov 14, 2009 | 09:56 AM
BarnieTrk's Avatar
BarnieTrk
Maybe not the answer you're looking for, and maybe the new seal MAY swell some and seal in time, BUT -- I tend to agree 59INA40, remove the fill plug from the top of the box, try to suck out some of the remaining steering lube with a small tube and 100ml syringe or turkey baster, then stick your grease gun in there and give it 6-8 pumps, replace the plug and never look back.........
BarnieTrk
Old Nov 14, 2009 | 10:25 AM
unibody62's Avatar
unibody62
Yeah, there was grease in it when I got it, with no seal at all. I guess that's the easy way. I may have to give it a shot. Trouble is, grease tends to separate, so it may end up seeping also.
