Hello, I am i need of info here. I have 93 F350 straight axel with 351W. And the oil pan is rotten and cant find any locally, except from ford for $576.00 OUCH. but there is many 302 pans for sale locally for less than $100.00. Can some one tell me what pans will fit this truck? If needed it has a 1895kg/4100lbs front axel.
i needed a pan for my 1996 F350 with 351. found one out in TN with no rust. people buy these truck motors all the time to swap into mustangs. but the 351 truck pan does not work in a mustang, so they can be had cheap. i got it to my door for $40. its used, but in excellent shape. i'd take a used ford pan anyday over some taiwanise reproduction pan. i too went to ford and they wanted around $500 for a new pan - no way!!!!!!!!!!
As mentioned above Rockauto.com has pan for your truck; 3 manufacturers range in price 70 to 90 dollars. Good photos of each and 302 also so you can compare appearance.
