Engine #2 Photos???
Old Nov 11, 2009 | 09:36 PM
F-250 restorer's Avatar
F-250 restorer
Engine #2 Photos???
Okay, guys, I don't want to go through thi$ again. This weekend I am going to yank my NEW engine with the failing oil psi, and hopefully drop in the new one.
It is basically the same build, but with the durashield coated pistons, and a comp 260 cam instead of the Isky 256, and with stock lifters.
Let me tell you, it is getting difficult to find a 75--81 core with stock bore.
I'd take and post photos this time around, but they'd be the same as last time.
Old Nov 11, 2009 | 09:45 PM
F-250 restorer
Should I also take photos of the rebuild?
Old Nov 12, 2009 | 05:45 AM
dustybumpers's Avatar
dustybumpers
I guess that I would, if nothing else, you are probably keeping them for your own enjoyment for later. nothing like looking back on things a couple of years later.
Old Nov 12, 2009 | 06:04 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Always enjoy pictures. Curious, any reason you went to the 260 cam? Reason I ask is I went with the 256 Isky in my 200ci build.
Old Nov 12, 2009 | 01:06 PM
F-250 restorer
I would have stayed with the Isky cam, but now I have a connection for inexpensive part through a national wholesaler, and he carries Comp Cams.
I thought the 256 was a great cam. It sounds stock, but delivers great power when needed. I hope you like it.
Old Nov 12, 2009 | 02:10 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Thanks for the reassuring. We both know what it costs to build these things and you're doing it twice. Your first was really clean looking, looking forward to seeing the second.
Old Nov 14, 2009 | 02:29 PM
F-250 restorer
It should be a mirror image of the first, but I may decide to spray the timing cover and oil pan a different color. Internally there will only be minor changes as well.
I will post the engine photos before it goes in.
Old Nov 14, 2009 | 03:23 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
There is always something you would do different the next time. Unfortunetly that came a little too soon for you.
Old Nov 14, 2009 | 03:58 PM
dustybumpers
that's ok, we're still interested in the project, kinda make believe about being there to help. wish I could be there, pics are the next best thing
Old Nov 14, 2009 | 07:40 PM
F-250 restorer
I'm really looking forward to seeing photos of YOUR project. It sounds absolutely complete restoration. I would love to see pix of all the goodies, especially the engine!!
Old Nov 15, 2009 | 06:11 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Finished plumbing fuel lines and linkage. Started on the Centech harness this week so I've got wires hanging everywhere right now. Some braided wire loom is due in Monday for the engine harness so I'll post a pic when I get the wires tidyed up a bit.
Old Nov 18, 2009 | 03:21 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Finished the plumbing and wiring. Starting to look like an engine now.
Old Nov 18, 2009 | 05:42 PM
F-250 restorer
First and foremost, let me say "Whow!"
That is a beautiful thing. That is, I believe, the classic inline aluminum head and intake? What size are the intake valves? And of course that makes me curious about pistons to go with the Isky 256 cam.
I also notice the angle for the header to bolt onto. Interesting.
And isn't that a late model alternator? I tried to use one, but couldn't get the bracket right and had to order an oem 100 amp. But I'm glad it worked for you.
It looks very clean. You've done a great job. What exhaust system is going on it?
Thanks for the peek.
Old Nov 19, 2009 | 06:19 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Yea, CI head and intake. Stainless valves, 184 intake, 150 exhaust. Bored .030 over w/ Keith Black flat top pistons, moly rings, Isky 256/256, double roller timing chain, DSII ignition, 9.7:1 compression. The alternator is an internal reg. 95 amp. Still thinking on the exhaust. I have my basic idea, but will talk to my exhaust guy after I get the header on.
Old Nov 19, 2009 | 08:54 AM
F-250 restorer
Very nice. I hope it works well for you. I almost went with the kb pistons myself.
It will be interesting to see/hear whether you go with the low, throaty growl or silent 'ninja' approach on the exhaust.
