i was on youtube lastnight and seen a clip of a sd 5L truck running a e303 cam it sound sweet can u get all the power out of a cam like that with out mas air
im running the ford motorsports e303 in my 408w and stock efi setup and im very pleased with its proformance. just a little video to let you hear her purr. http://www.youtube.com/mk3gtivw#p/u/4/FP48Zz93BgY
how can you run a 408 on the stock SD computer and expect it to know what its doing? i suspect you will find it running either very lean or very rich in which case both are bad.
cool video but doesnt really tell how the motor is working properly. any codes? can you post your motor specs
the e303 isnt a great cam, far better choices out there. most mustang guys like the alphabet cams but should understand what works in a stang doesnt in a heavy 4wd.
