05 Ranger TDI help wanted
.The truck drives realy good but it has some electrical problems,and there are so much fuses and relais in it and nowhere a explanation for wich is for what.the local dealer has no info because they speak spanish and i do not
My probs are-Wipers do not work I measured no power at the motor
-All electrical windows refuse to work
-and some other little things witch I already fixed using the info from this forum
My question is can somebody let me know witch fuse and relais belongs to......
Even the electrical map from a gasser is welcome I hope they use for some things the same number.
Thanks
https://www.fleet.ford.com/maintenan...ls/default.asp
