Off Track Mirror
Old Nov 11, 2009 | 11:59 AM
RePoEd'02's Avatar
RePoEd'02
Off Track Mirror
I got the F250 SRW 7.3 and the passenger side mirror is off track some how. I have googled and serched high and low for a fix. I do not want to replace these just yet with the heated '08s. Does any body know how to get inside the mirror? I can't seem to pry or find any tabs to move to allow access.
Thanks
Bryan
Old Nov 11, 2009 | 01:23 PM
Layson's Avatar
Layson
Did you push your hand on the glass and push it in and out. There are little plastic pieces that extend from the back of the glass (actually a plastic backing) into the little motors. You can pull that glass out if you really want to. It is a pain to pop back in but at least you can see what is going on.
Are you sure that your mirror adjuster switch isn't broken. That would keep it from moving too.
Old Nov 11, 2009 | 01:37 PM
RePoEd'02's Avatar
RePoEd'02
No, it moves but like if you want it to go right it goes down and right. I think the wife smacked it on something.
Bryan
Old Nov 11, 2009 | 01:40 PM
Layson's Avatar
Layson
Try pushing it in manually and see if anything feels out of whack... side to side and up and down...
Old Nov 11, 2009 | 01:42 PM
Layson's Avatar
Layson
this kinda shows you how they come apart... not too fun of a project LOL
http://www.kwmuth.com/techsupport/pdfs/21000220.pdf
Old Nov 11, 2009 | 02:35 PM
Lstanley's Avatar
Lstanley
This happened to me on my old truck and it happened to be the power mirror adjuster switch. There are little contacts inside the switch and they were not contacting properly, so I took the switch a part cleaned it and then oiled it up. I then put it back together and it worked fine for me after that.
Old Nov 11, 2009 | 04:01 PM
jrf250's Avatar
jrf250
My truck was doing nthat also. Went to a junk yard and got one from a F150 and changed it out and worked great. Only cost me $4.00 for the switch.
Old Nov 11, 2009 | 04:18 PM
JockD's Avatar
JockD
Take your old switch out and either try to fix it or take it to the junkyard so they can match it. The switch fits more than the Superdutys, so having it with you will help the yard match it.
Old Nov 11, 2009 | 11:02 PM
RePoEd'02's Avatar
RePoEd'02
Layson.... Reading the PDF makes me want to .................PUNCH A BABY! I think I will look the switch cleaning tomorrow.
Thanks for all the ideas and replies guys.
B
Old Nov 12, 2009 | 05:42 AM
ChunderDownUnder's Avatar
ChunderDownUnder
Same problem with mine. pulled the switch, just be careful how you take it apart. Adjusted the contacts and all is good
