Modular V10 (6.8l)
overhead console
Old Nov 11, 2009 | 09:54 AM
bigjp's Avatar
bigjp
overhead console
ok my overhead console isnt working now looked at all the fuses, they look good what should i check next.....help.... thanks
Old Nov 11, 2009 | 09:05 PM
Ex03AK's Avatar
Ex03AK
Here is a link to a thread with instructions to an easy fix.
https://www.ford-trucks.com/forums/4...-gone-out.html
It took longer for my soldering iron to warm up than it did to remove the console and circuit board. I did in about 10 minutes. Just make sure you use a lower wattage iron and you might as well re-do all the chips at once. Also watch out for a falling chip as you remove the console. One might have completely fallen off of the circuit board. They are very small and hard to find otherwise.
Good luck!
Stew
Old Nov 11, 2009 | 09:44 PM
Ex03AK's Avatar
Ex03AK
The original poster of the instructions in the thread I linked you to has removed the pictures from the links. The chips look like a flat silver bar about 3/8" long x 3/16" wide and have a 2-digit number like 60 or 70 on them. There are several of them.
Stew
