Return line kits
Old Nov 11, 2009 | 08:35 AM
WEST AUSSIE 94 250's Avatar
WEST AUSSIE 94 250
Return line kits
The return line kits I have found on ebay dont look right to me. I need the late model 7.3 kit but the ones I have seen dont seem to have the correct injector fittings. They all have 8 two legged caps 4 straight through and 4 90 degree. Mine has 2 three legged caps that join the left and right bank. I cant find them at rockauto either which would have been good as I need to order glowplugs at the same time and didnt want to pay two lots of freight. Any suggestions.
Old Nov 11, 2009 | 09:46 AM
PLC7.3's Avatar
PLC7.3
Visit......... return line kits Oregon area
Oregon Fuel Injection, diesel injector pump, injector, Powerstroke injectors, turbo and turbo parts for Ford Diesel pickups 6.9 l, 7.3 L, 6.0 L & 6.4 L
or
7.3 L Ford Diesel Fuel Injectors Fuel Pumps Accessories Make sure the picture matches the one on your truck........ specify TURBO IDI
Old Nov 17, 2009 | 08:47 AM
WEST AUSSIE 94 250
Midwest quoted me $44 for the kit and $224 freight. Do these caps tend to break when you remove them or can I just put in new orings and reuse them. I am only replacing them because I am going to do glowplugs and have read that I can cause air leaks from the movement. I just wanted to have the parts here ready. Could I get the kit from ebay and reuse just the original three way caps?
Old Nov 17, 2009 | 12:38 PM
PLC7.3's Avatar
PLC7.3
You could do any of the above......... You need to get a cousin or sister in USA to purchase it and send as a gift.
I have left them in place and worked under and around them with good luck.... just be gentle.
Old Nov 17, 2009 | 01:39 PM
Franklin2's Avatar
Franklin2
I re-used all my caps and didn't have any problems.
Old Nov 17, 2009 | 02:45 PM
IHdieselfan's Avatar
IHdieselfan
The newer kits do away with the three way peices.
Hey do you have ULSD in australia
Old Nov 18, 2009 | 02:48 AM
WEST AUSSIE 94 250
We only have one kind of diesel over here and I dont know if it is ulsd. Other than bio. I would suggest that if it is considered the right way to go then that is what the gov would mandate.
Why do the new kits do away with the three ways and how do you link the two sides without them.
Old Nov 18, 2009 | 08:08 AM
Happyreefer's Avatar
Happyreefer
same for me, here are the correct tee's you need..
ford part numbers and prices I paid here at the dealer..
3-way tee F3TZ-9A564-B $4.10 usd
1-way tee F3TZ-9A564-A $5.47 usd
Red Rascal
Jun 30, 2016 08:28 PM
donfordman
Dec 17, 2013 05:19 AM
R. Victor
30
Jul 6, 2013 09:02 PM
