The Definitive 2WD Excursion Suspension Upgrade
#32
Thanks again
Laki
#33
I have had these springs on my truck for about 6 months when I had to tow a 5'x12' trailer from IL to FL. In southern GA my A/C started dying out. I looked underneath at a rest area I saw that the top curved leaf had raised up and hit the rear A/C lines causing the refrigerant to leak out. The weird thing is it looked like the back end only dropped a couple inches lower with the trailer and full load but I guess it was enough to cause contact.
Since I never use the third row (dont even have it installed) I was planning to just block off the lines to the rear on the PS fender and get heater hoses for a Excursion w/o rear heat. I assume that the front A/C is up to cooling the front two rows?
Anyone else had this problem?
#34
I was going to be installing these tomorrow and now I am hesitant. I tow a 24ft car hauler with mine and if yours was only towing a 12ft something is up. Was the trailer very heavy on the tongue? Maybe a couple large bumps sent it screaming up into the lines? I was thinking of covering my lines in some 3/4-1" heater hose and also something on the lip of that top leaf. Their dosnt seem to be any room for bending those lines out the way as i thought there would be.
I was even contemplating cutting that top leaf back on that side. Im not to sure how that top leaf actually does anything as it does not have 2 contact points on the leafs below to distribute its tension.
#35
#36
#37
It looks like he installed the wrong b code. The one ending in "ca" I believe has the overload on top that will hit the ac line. There is one ending in "cb" that doesn't have the top overload. That needs to be taken out if u can or u run the chance of hitting the ac lines!!!
Stewart
#38
Rear B code springs: Part #3C3Z-5560-CB
Stewart
#39
Dont think I installed the wrong ones per the OP, the part # referenced in the beginning of this thread is 3C3Z-5560-CA and that part number checks over to the VIN he has listed.
If it is the wrong part can the OP update the original info on the front page? I dont want this to happen to anyone else. I have to stick to these springs since I dont want to spend $550.00 bucks to get the CB springs.
#40
#41
#42
I've got my local dealer getting me these CB leafs and will be installing them next week hopefully. They are almost 30$ cheaper each compared to the CA's. New leafs were a no brainer to me since my stocker's were already sagging and wasnt looking to do a 6" lift.
I'm going to be installing a Daystar 2" front leveling kit & Fabtech 1" spacers/Ubolts to gain a ~3"F/4"R Lift. I feel this was a smarter option using the factory leafs and coils and I wanted to maintain a slight rake since my truck sees towing duties pretty often.
My only concern is these CB leafs wont get me the 3" lift as the OP and others have seen. Can anyone yet verify the CB leafs giving the same height and ride quality?
#43
Well I got my setup installed today and I am AMAZED at how nice the truck rides. Its certainly not "school bus" stiff as I was thinking it would be. Got about 3.5" on the back and 2 3/4" up front with the setup i posted above.
For those having a hard time finding longer u-bolts you can get them from FABTECH and they are BEEFY!
U-bolt Kit - FTS351UBK
1" Block Kit - FTSBK1
Instead of grinding on the spindle for more adjustment I got camber blocks from Advance Auto. Manufacturer MOOG - K8974 1 Degree. They got the wheels almost perfect but I will have a definite answer later in the week when my buddy can squeeze me in for a true alignment. Moog does make a global adjustment piece part # K80108 but it is a little more pricey but goes from 0-3 degrees so you will always have enough play.
I did use the "CB" leafs and they fit great MINUS having to hack about a 1 1/4 inches of the passengers "slapper/support" leaf on the very bottom of the leaf stack. It was pushed hard into the MBRP 4" exhaust im running. Once I get a alignment done and wash the truck up I'll post some pics
#44
I've been a reader here for a while and have just recently become a member. I have the spring-thing going on and been trying to wrap my head around all the info. This has been a very helpful thread for 2wd spring upgrades. It's a no-brainer for the rear B's.... other than whether to do a spring mod or the block approach. The front Z's seem to be a good upgrade too.
I'm definitely wanting to improve the stability/firmness of the ride. If I can add 2"-4" lift to level or create a slight rake, that will be even better.
What's the weight rating on the Z's? Has anyone plugged in the heavier F350 springs that are rated at 6000# ? (I don't know their code). I will probably need a spacer to achieve the lift but, more importantly, I want to make sure I have plently of spring. Any new thoughts since this thread was first developed would be appreciated.
Also, can't say enough good things about Stewart_H and Toreador Diesel sharing their knowledge.
#45
I checked an '05 f250 a couple weekends ago..
Both crewcab w/6l, front axle weights on door sticker read:
Z-code. 4850 (or 4800 don't recall).
Y-code. Was 100 lbs less.
I think i also saw an x-code with 4400 lb.
Remember codes changed for model year 2005 for the front coils, even for 2wd vs. Earlier years.
