tachometer
Old Nov 9, 2009 | 07:33 PM
Dev's Avatar
Dev
tachometer
hey I'm bach I don't want to pay $150 for an aftermarket diesel tach cause this is a gas truck that I put the diesel moter in so I took the one that was in the diesel truck and am trying to wire it in and it reads 650rpm at idle but when you rev it up and it gets to 2000rpm it drops out and wont read properly I put a new sensor and have checked all of my conections over and over I any ideas?
Thanks
Old Nov 9, 2009 | 09:22 PM
Dave Sponaugle's Avatar
Dave Sponaugle
How much of the original gas wiring is still in the truck?
Old Nov 9, 2009 | 09:49 PM
PLC7.3's Avatar
PLC7.3
Check the wires going into the sensor ...... wire cover can pull back and fan wind causes them to short out....
Old Nov 9, 2009 | 11:52 PM
Dev's Avatar
Dev
tachometer
everything is still in the instrument cluster and the wires coming through through fire wall I'm just runing my owen separet wires for the diesel tac and it's a manual trany.
Thanks
Old Nov 10, 2009 | 07:06 PM
Dave Sponaugle
If everything is still under the dash for the gasoline motor, my guess is you are getting a signal through the insturment cluster stock wiring causing your trouble.
Old Nov 11, 2009 | 10:14 AM
shanes66charger's Avatar
shanes66charger
do the two wires from the factory 6.9 tach sensor go DIRECTLY into the cluster? How does the sensor function (name of it)?
Does one wire FEED power TO the sensor and the other sends signal to the tach?
I'm assuming the sensor gets power from somewhere?
I guess i'm wondering how the whole setup fuctions? Looking to do some testing before spending 75 from my dealer for sensor.
thanks..........didn't mean to hi-jack your thread.
Old Nov 12, 2009 | 09:46 PM
Dave Sponaugle
The sensor is a Hall Effect unit.
Generates it's own power/signal, so yes the two wire go straight to the tach.
If you do a search on "Hall Effect" you will come up with a better explanation than I can give.
