Another Zoodad Question
Old Nov 9, 2009 | 04:37 PM
03-6L-X's Avatar
03-6L-X
Have a 2000 F250 7.3L with AFE stage II.
Will this help with the airflow even though the battery is blocking a "true direct flow".
I have tried reading through the other posts and have not seen any comment except for the 6.0L's.
Thank you.
Old Nov 9, 2009 | 10:18 PM
mueckster's Avatar
mueckster
I have the AFE Stage 2 with the Zoodad mod. I did it before putting on the AFE. I would say that the Zoodad helps. I put some screen wire over the hole because I was getting alot of bugs and such on my filter. So, I would say the air is getting to it just fine!
Old Nov 10, 2009 | 12:14 AM
4inchlovin's Avatar
4inchlovin
Im with Roland on this one... Any extra air is helpful. These trucks pull a ton of CFM.
Old Nov 10, 2009 | 12:46 AM
jkidd_39's Avatar
jkidd_39
I saw right around a 15 degree temp drop and my air temp sensor is zip tied way back by my PCM..
Old Nov 10, 2009 | 11:00 PM
renyren's Avatar
renyren
I saw at least a 15 degree drop in intake air temp as well. Very easy mod to do.
