Fog lights not working
Old Nov 8, 2009 | 10:21 AM
rtazz17's Avatar
rtazz17
Checked fuses,Dont know what relay to check. Theres no juice at the lights per voltmeter. Juice at switch ... Bulbs are good...If its on a relay I could check that if I knew which one.
Old Nov 8, 2009 | 03:50 PM
rtazz17's Avatar
rtazz17
Ok, spent 3 hours searching for the problem. Cant find it. Im done.. I think Im going to run wire from the oem fogs to the cab and put them on a toggle. Really I want to be able to put the fogs on and off when I want not just when headlights are on. So does anyone know if how I stated to do it is ok? Do I need to put anything else like a relay or something. Im not really sure what a relay is but I read the oem fogs are connected to a relay under the dash...
