Longer To Start
Old Nov 8, 2009 | 09:51 AM
Automator's Avatar
Automator
Longer To Start
I finally tried synthetic (Rotella 5-40) and shortly afterward I began experiencing a longer crank time. It isn't real bad, going from about 3 seconds to less than ten seconds, but was wondering if that is normal. Restarting after it has run is instantaneous still so it sounds like it may be taking longer to build enough pressure in the HPOP for the injectors.
Old Nov 8, 2009 | 09:56 AM
87 F-150 I6's Avatar
87 F-150 I6
Your starter could be dieing, how old is it?
Old Nov 8, 2009 | 10:04 AM
Automator's Avatar
Automator
Best I can tell it is the original. I did put a new flywheel on about five months ago, it wasn't bad but the motor was out and a good time to do it since there was some wear on it.
Old Feb 10, 2010 | 07:04 PM
Automator's Avatar
Automator
While putting in my cip I found why it was taking longer to start ... turns out I was running on only one battery. The positive terminal on the passenger side wasn't making good contact and when I went to put the negative back on that side first, the dome light didn't come on. Good thing I switched to synthetic oil and had new batteries. Starts like it used to now!
Old Feb 10, 2010 | 08:26 PM
megawatt00's Avatar
megawatt00
Thanks for posting what the problem was Dave
