sloppy five speed
Old Nov 8, 2009 | 09:06 AM
nateairman's Avatar
nateairman
sloppy five speed
My five speed has alot of play between the gears and once it is in gear. It never pops out but it is a pita to shift some times cause it is hard to tell where the shifter is. I tried to take the plug out of the trans to see what the fluid level was and the po has done some custom rounding of the square drive making a little difficult to work with. What fluid should I put back in this thing when I get it open? and what do I do with the sloppy shifting? It has a new clutch pedal bushing and when I find the parts I will change it out.
