Subscribing. I need to replace the rear main seal in my 460 ('86, I'm thinking 2-peice). I have already JBweld/fixed a pin hole sized rust hole on the oil pan... I wouldn't mind changing the oil pump/pickup, oil pan, rear main seal and all the core plugs; I just hate the thought of all that wrenching!
Yes I have the one piece seal it seems to be easier to pull the engine and pull the rear main cap to put the seal in. I was just wondering how everbody else does this.
I have never loosened the main cap to replace a 1 piece seal. If you dont need an oil pan gasket I think its easier to pull the trans.
I patched a pan with JB weld a couple years ago on a 7.3 PSD, still holdin'!
