Boost Leak Detector ... built but .....
Old Nov 6, 2009 | 01:31 PM
afonda's Avatar
afonda
I cant get it to stay in !!! (that don't sound right!! )
For real... I get to about 10 or 15 psi and it blows off..
I used a 3 inch pvc end cap and roughed up the edges with sandpaper so it would hold better... but it still didnt hold too well...
At 15 psi... i heard no leaks though. I am guessing that it is probably good to go so far as no boost leaks.
I was able to tighten up some of the IC Boots but not much.
How do you keep the darn thing from blowing off?
Old Nov 6, 2009 | 01:58 PM
87 F-150 I6's Avatar
87 F-150 I6
Might try some hairspray
Old Nov 6, 2009 | 02:28 PM
DieselCamper01's Avatar
DieselCamper01
I too have had mixed results with mine. Sometimes it stays ok and other times it pops off without a lot of pressure. Give that clamp all you have and then a little more.
Old Nov 6, 2009 | 02:31 PM
Fire Rooster's Avatar
Fire Rooster
I would say 15 psi is pretty well good enogh
Old Nov 6, 2009 | 02:59 PM
F350-6's Avatar
F350-6
You did put a hose clamp on it, right?
I'd agree that if there's no leaks at 15 psi then you should be good.
Old Nov 6, 2009 | 04:29 PM
5.0 Junkie's Avatar
5.0 Junkie
I had to hold mine. I could hear air rushing but it sounded internal to me.
Old Nov 6, 2009 | 06:52 PM
danskool's Avatar
danskool
Go Bills !
I took my hand grinder and scuffed it up. Pretty good. Rubbing my hand across it feels like what a city street feels like. . Don't have to be a perfect seal but it needs to hold. So it don't pop off and catch you in the face. In only use 15 also.
