replacement distributor
Old Nov 5, 2009 | 07:56 AM
ladelld33's Avatar
ladelld33
fellas you all know that i'm rebuilding my 84 f-150 302/c4 trans 308 rearend. who makes a good replacement distribtor for this engine. nothing fancy just want to replace a worn unit without a large expense or is it easy to rebuild one??? the new engine will be punched out to 308 with an upgraded cam very mild.
Old Nov 5, 2009 | 09:57 AM
Franklin2's Avatar
Franklin2
Just get a rebuilt unit from the local store. It's no different than a alternator or starter, unless you do want a performance model, which do cost a little money. The performance models are more adjustable than the factory unit though.
Old Nov 5, 2009 | 10:53 AM
ladelld33's Avatar
ladelld33
kool thanks maybe i'll check out auto zone and oriles
Old Nov 5, 2009 | 11:59 AM
spikedog's Avatar
spikedog
I was very happy with a Malloy Unilite distributor. Easy to set up, and had adjustable mechanical advance curve along with the vacuum advance.
