Sponsored by: Real Truck
Gear Set Help!
Old Nov 19, 2009 | 08:16 PM
TexasRebel's Avatar
TexasRebel
bearings can be changed, but if they failed and spun in the housing, the housing will be torn up...
there is no repair.
Old Nov 19, 2009 | 08:28 PM
bubbasz1's Avatar
bubbasz1
Here ya go, hopefully he still has it.
'05 Ford Dana 60
'05 Ford Dana 60 - $750 (Shelby Twp)
Date: 2009-11-18, 4:07PM EST
Reply to: sale-zerq7-1472037483@craigslist.org [Errors when replying to ads?]
I have a front out of an '05 with 3.73's and only 29k miles on it. It is complete with track bar, steering , AND trailing arms! This is complete. $750
If anybody is interested...I may still be able to get the matching rear
Things I will consider trading for.
FRONT LOADING WASHER AND GAS DRYER.
Cash.
A good lower mileage fuel injected 351 and cash.
Old Nov 19, 2009 | 08:38 PM
5.4L to Freedom's Avatar
5.4L to Freedom
thanks bubbasz1 but I need the leaf spring version, I'm not sure of the coil one can be converted. I found a few, but now what I need help with is the actual diagnosis... my chilton and haynes manual aren't worth the paper they are printed on and I dont want to spend the money on an alldata subscription.
I've never taken apart a ford front end before, and can't seem to find a parts diagram, I was thinking I would start pulling apart and then look for broken things as I went thru it.
Old Nov 19, 2009 | 08:42 PM
bubbasz1's Avatar
bubbasz1
See, that's what you get for having a 2Wd superduty. Bad me.
Old Nov 19, 2009 | 08:46 PM
bubbasz1's Avatar
bubbasz1
Here's one in PA for $600.00 out of a 2000, should work but it doesn't say what gear ratio it is.
2000 ford front dana 60 axle
Old Nov 19, 2009 | 11:14 PM
5.4L to Freedom
thanks again b, I'll check this one out... now I just found a flaw with my plan... how am I gonna get the new axle out of my buddy's truck?
I read these things weight between 500 and 1000 pounds depending on how complete the axle is, and how should i get it out of the truck. I dont have a cherry picker or a place to mount a come along on the cieling, think me and 3 or 4 other dudes an lift it?
Old Nov 20, 2009 | 12:46 AM
TexasRebel's Avatar
TexasRebel
500 lbs?
that seems a bit high, but if that's accurate there are a few things you can do...
1) drain it
2) remove the axles
3) remove the spindles/hubs
that will take it down to the housing and carrier.
AbusedAmericanRust
18
Feb 3, 2014 08:27 PM
The Freak
Oct 24, 2012 01:29 AM
5.4L to Freedom
Nov 29, 2009 03:33 PM
