Sponsored by: Real Truck
Jack stand recommendation
Old Nov 2, 2009 | 01:58 PM
galightning1's Avatar
galightning1
OK...it's stupid question day! I've decided to do my own oil changes and need to make sure I don't kill myself rolling in under my F350 (GVWR - 13000lbs). I've always been under the impression that one should use a stand that is rated at least half the vehicle weight. True or False?
Old Nov 2, 2009 | 02:25 PM
cjspack's Avatar
cjspack
I don't need to jack up my '02 F250 to change the oil. There's plenty of room to work under it w/out lifting it up. Give it a try.
Old Nov 2, 2009 | 02:29 PM
galightning1
I did'nt mention that I need more room to change the fuel filter located on the frame rail under the driver's seat....thus the need for jackstands.
Old Nov 2, 2009 | 04:14 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
I change MY filters under my truck all the time! I never jack it up to change oil or change fuel filters. If you are bigger around than me....(I'm a little overweight), you MAY need to take a little weight off the body.....(of the truck). Your truck weighs a LOT less than 13,000 lbs!!!!
Old Nov 2, 2009 | 04:28 PM
smlford's Avatar
smlford
First off if you were going to get jackstands I would STRONGLY reccomend that you get a pair that is rated for the total weight of the truck not half..Afterall the front of your truck weighs much more than half of the total...
BUT I would reccomend Rhino ramps that you can just drive up on. I have a pair and use these when I don't want to hasle with my 2 post lift.
Here's what I'm talking about...
Blitz Rhino Ramps — 12,000-Lb. Capacity | Car + Truck Ramps | Northern Tool + Equipment
They come in various weight ratings and I would suggest nothing lower than 8K for SD's
Old Nov 2, 2009 | 05:30 PM
BareBones's Avatar
BareBones
I pitched an 8-person tent under my superduty last summer, with stand-up room for both a 6' tall man and the horse he was riding!
You don't need jackstands to change the oil....
Old Nov 2, 2009 | 06:11 PM
sandmanf250's Avatar
sandmanf250
my 2 cents says fumoto while your doing it this time.
TJ SD
Feb 16, 2015 11:43 AM
alchemist1
Oct 3, 2012 10:18 AM
fromttt
Jul 30, 2012 05:44 PM
dpii
2004 - 2008 F150
Nov 6, 2011 01:33 PM
papadelogan
Jan 31, 2009 12:43 PM
