c4 problem
Old Nov 1, 2009 | 11:18 AM
DeepRoots's Avatar
DeepRoots
c4 problem
I just bought another truck..... yeah I know.
anyway it was a c4 in it, which I have never worked with.
There are the two pipes that are used for the tranny cooler pass side, and there is one pipe that looks like it goes to the top pass side, almost near the starter.
When I bought the truck and they shut it down there was ATF leaking from that pipe.
Any idea what it goes to?
Thanks,
Drew
Old Nov 1, 2009 | 01:54 PM
Lazy K's Avatar
Lazy K
Only thing I can think of is the dipstick tube.
Old Nov 1, 2009 | 02:22 PM
DeepRoots's Avatar
DeepRoots
nah, I'll have to see if I can wiggle a camera up there enough to get a photo.
Old Nov 1, 2009 | 03:52 PM
85e150's Avatar
85e150
Does the C4 have a vacuum modulator like the C6? Those can leak, and if the tube is hanging instead of being connected to the carb or manifold, it will leak there, and shifting will be at higher rpms and a hard shift, iirc.
Old Nov 3, 2009 | 06:45 PM
DeepRoots's Avatar
DeepRoots
yeah it does. C4 apparently has the vac mod on the driver side rear. I wonder if this is just an overflow of sorts....
I dunno, I'm back to work offshore, I'll figure it out in a month when I get home again.
Old Nov 3, 2009 | 08:45 PM
Sand_Man's Avatar
Sand_Man
I think the tube you're describing is a vent. Does it point down? If so, it could have been over-filled or the trans may be toast and it's overheating and puking fluid out.
Old Nov 4, 2009 | 10:21 PM
DeepRoots's Avatar
DeepRoots
yeah, points down.
It was leaking when I recieved the truck.
Well, i've rebuilt c6's, I doubt the c4 is much different, shouldn't cost much to do.
I'll have to mess around with it when I get home.
thanks everyone,
Drew
FarmingFord
Dec 10, 2014 10:17 PM
FarmingFord
Dec 10, 2009 08:24 AM
DeepRoots
Dec 8, 2009 04:46 PM
FarmingFord
Virginia Chapter
Jun 16, 2008 12:54 PM
drew1701
Sep 24, 2000 06:02 PM
