3 sp tailshaft..... HELP!
Old Oct 31, 2009 | 08:22 PM
custom cabby's Avatar
custom cabby
Okay, follow me on this....
'68 F100 3 speed manual trans backing 360 FE
When I lowered my truck it pushed the driveshaft far enough up into the tranny to butt the yoke up against the tailshaft and create some damage to the seal and the tailshaft. So, while replacing the output shaft seal, I was faced with a lip where the metal was damaged under the seal. I tried to file on this a bit to allow the new seal to seat in properly. No luck because I believe the diameter of the shaft where the seal seats has been distorted possibly by the heat caused by friction or the blow from the driveshaft when I experienced axle wrap one day (which resulted in having to have a custom driveshaft made). So........... I need a new tailshaft, unless you guys can give me any pointers on what to do to cure this issue and allow a new seal to seat. Any suggestions welcome.
Old Nov 1, 2009 | 02:10 PM
DLP Performance's Avatar
DLP Performance
Hit the junkyard.
Old Nov 1, 2009 | 03:33 PM
68horses's Avatar
68horses
From your explanation, it sounds like the problem is with the tailshaft HOUSING, not the tail shaft itself. Fairly easy to change, by comparison.
Gene
Old Nov 2, 2009 | 04:36 AM
custom cabby
WOW!!!! Talk about a headache! After 3 seals, 2 destroyed Dremel bits and about 3 hours total..... It's in! And if it should decide to leak, ..... haven't gotten that far to figure it out... fingers crossed. Thanks guys
