I have looked at the past posts and mine seems diferent than what i have found. On my 98 Expy the front washer will not spray until i have sprayed the back window. Then it sputters and finally sprays the front. Is this a leaky hose? You would think the front would be more likely to work than the back. The wipers go back and forth but no spray. Hope someone has an idea. Thanks
Tony Warren
Nebraska
PS. This is my wifes rig, and she cant seem to understand why i have not fixed this yet. Just because i can fix anything on my old ford she thinks i can fix anything. Teh Teh. So please help me to continue her dillusions.
Sounds alot like mine. I believe the problem is in the switch (turn signal stalk). I have to press the button, jiggle the turn signal, say a chant, and then sometimes it'll work.
Ive tried the chant, rant, rave, curse, stomp, scream and yell. The only thing that works is if i wash the back window first. It is really weird. Anybody else?
